Engine Hiccup
Old Jun 22, 2018 | 01:27 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Engine Hiccup
Hi There,
Re: 2006 ML500
When engine is warmed up, often not always, when stopped and in idle, engine keeps trying to install and then comes back on within a second or to. If I shift to N, the hiccup stops and engine runs smoothly.
Any insight will be appreciated.
Thanks,
Old Jun 23, 2018 | 02:33 AM
flybd5's Avatar
Veteran: Marine Corps
2014 Smart ForTwo Passion Cabrio
Originally Posted by anavabi
Hi There,
Re: 2006 ML500
Thanks,
You need to 1. post your vin to your profile and 2. have the car's computer read with a scanner that understands MB codes and post the results of that.
Old Jun 23, 2018 | 03:50 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What does this mean............... engine keeps trying to install ?
Old Jun 23, 2018 | 09:56 AM
anavabi's Avatar
Typo, I meant stalll. Revs slows with some vibration, as if gasping for air or fuel.
Old Jun 24, 2018 | 04:37 AM
I had the same exact problem with my 500 and believe it or not changing the Trans. filter and fluid corrected the problem.
Old Jun 24, 2018 | 09:34 AM
anavabi's Avatar
Would you please let me have the instructions for this work.
Also what is a good code reader apart from the Star which is too costly for DIYer.
Old Jun 24, 2018 | 10:43 AM
Here is the
scanner scanner
you should buy. It will read every and all modules in your veh.
As for changing the trans. filter and fluid, it is not like the old days where you fill the fluid through a fill pipe in the eng. compartment. Almost every manufacturer has eliminated the fill pipe and you now need a hand or pressure pump to inject the fluid upwards into the pan.
If you do not have automotive experience, doing this by yourself could damage your transmission. You decide what you want to do.
Old Jun 24, 2018 | 12:06 PM
anavabi's Avatar
Here is the scanner you should buy. It will read every and all modules in your veh.
https://www.youtube.com/watch?v=1qe5iryrFzE
Thanks Maj. I'll have to watch it couple of times to see if I can do it without a car lift!
As I'm offered a good deal on an Innova 3160g, would this be an equivalent to the one you recommend?
Old Jun 24, 2018 | 01:04 PM
You asked me for my recommendation and now you want to know about something different. Make your own decision.
Old Jun 24, 2018 | 01:12 PM
flybd5's Avatar
If you have never done this before, take it to a shop and have someone who knows what they are doing do the work. Doing it without a lift is masochistic, and as you can see from the video you need special tools and a proper scanner. Spend a little money and get it done right, or do it wrong, ruin your transmission and that's the end of your car.
I'm out of this thread.
Old Jun 25, 2018 | 10:21 AM
anavabi's Avatar
Just talked to my mechanic and he said because I've never changed the transmission oil, at least since my ownership in 2010, it may cause problem if I change the oil now. So he just wanted to warn me.
Can this be true?
I never changed it because the manual said so!
Old Jun 25, 2018 | 02:06 PM
Can this be true?
It's BS. It's an old wives tale.
Old Jun 25, 2018 | 02:08 PM
anavabi's Avatar
fair enough. Thanks
Old Jun 26, 2018 | 04:35 AM
flybd5's Avatar
Can this be true?
So your mechanic says not to change it because you've never changed it? WTF... you're using the wrong mechanic.
Old Jun 26, 2018 | 10:09 AM
anavabi's Avatar
He says that the worn clutch pack is now relying on metal debris in between discs to generate friction. If the deris is removed by new oil, especially if flushed, the worn out cluch pack will have much less friction.
Old Jun 26, 2018 | 10:15 AM
Now you have to make a decision.
Old Jun 26, 2018 | 11:02 AM
flybd5's Avatar
I wonder how he came to the conclusion the clutch pack is worn out without disassembling the transmission... If what he said were true, you'd have a lot more problems than a "hiccuping" car.
Old Jun 26, 2018 | 01:22 PM
anavabi's Avatar
I can live with the hiccup for now. Thanks for your insights.
Old Jun 26, 2018 | 01:31 PM
flybd5's Avatar
If you think you have problems now, wait until the entire tranny goes because you didn't service it.
Old Jun 26, 2018 | 01:40 PM
anavabi's Avatar
You're making me nervous! I'll have to think about it harder.
Old Jun 26, 2018 | 01:49 PM
anavabi's Avatar
So I just checked with the Service at the local MB, he confirmed that for older model it's best to leave the transmission oil as is, for the same reasons.
Go figure!
Old Jun 26, 2018 | 05:07 PM
texterted's Avatar
ML420 W164 (2009)
Probably because the sump pan bolts often snap when you try to remove them.
Old Jun 27, 2018 | 07:20 AM
flybd5's Avatar
Go figure!
The service schedule for your car says the transmission fluid must be changed ONCE at 39,000 miles. Do you have a record of it ever having been done?
Old Jun 27, 2018 | 07:38 AM
anavabi's Avatar
For sure it hasn't been done.
So why the manual doesn't reflect that?
Old Jun 27, 2018 | 03:28 PM
flybd5's Avatar
Because the owner's manual and the service schedule manual are two different books. You should have both.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
