2008 ml320 cdi
Old Jul 15, 2018 | 11:48 AM
jpd686's Avatar
2008 ML320 CDI
2008 ml320 cdi 2510-001 actuator
i have just purchased a 2008 ml320 cdi it currently has a engine code of p2510-001 which i believe is the boost pressure regulator. Vehicle is in limp mode and is not making boost. The old owner has told me a mechanic said it needs a new turbo. I have not pulled it apart yet to visually inspect the turbo. Just looking for any other tips you veterans may have. This is my first Mercedes but not my first turbo diesel vehicle. Vehicle has 182,000 km in it.
Any help would be greatly appreciated. Thank you!
Old Jul 15, 2018 | 10:09 PM
jpd686's Avatar
2008 ML320 CDI
I think it’s the turbo actuator from what I gathered on this forum which is not sold separately. Was going to pull off and inspect it. Just looking for desperate opinions.
Old Jul 16, 2018 | 07:33 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Without your vin #, the positioner is part of the turbo and is not sold separately. And it costs approx. $3,700.
File Type: pdf
Old Jul 16, 2018 | 10:04 PM
jpd686's Avatar
2008 ML320 CDI
It is 100% the actuator connections that commonly tend to disconnect from the circuit board. I took it off and had a look they were complete separated. I didn’t have silver solder to solder and I also have no experience soldering so I’ll have to find someone capable of it that will do a good job. I just pushed the connections back where the are supposed to go and the turbo started working perfectly. Once the vehicle got up to temp I assume the metal expanded and stopped making contact so the turbo stopped working again.
At least I know what the problem is. Does anyone have any tips for soldering or have another solution on how to attach those points? I brought it to an electronic repair place and they said the wouldn’t touch it cause it needed to be silver soldered...
Old Jul 17, 2018 | 03:02 PM
mRaposo's Avatar
ML350 2009 CDI
If you really need silver solder, you may have to look for a goldsmith.
Old Jul 17, 2018 | 09:51 PM
sclasspilot's Avatar
2008 ML320 CDI with every option code including Offroad pack, 1978 450SEL
MB uses silver solder because the location of the actuator is subject to high heat from the turbo. However silver solder is more brittle than lead based solder, resulting in the failures.
You can just use normal solder, but be sure to scrape the silver solder from the pads first or it wont stick. I used a Dremel to prepare mine.
Given you have no experience in soldering and this is a very expensive part to get wrong, just take it to your local electronics repair shop and they will assist you for a small cost.
Old Jul 18, 2018 | 08:52 PM
jpd686's Avatar
2008 ML320 CDI
Well i took it a tv repair man and he said it was silver soldered and there was nothing he could do. So I took your advice and ground off the silver with a dremel and soldered it back by myself. Now my turbo is boosting. Just need to clear the code or just let it clear itself. .
Old Jul 18, 2018 | 09:04 PM
texterted's Avatar
ML420 W164 (2009)
Well done and fingers crossed!
Old Jul 18, 2018 | 09:06 PM
Well done on completing this job yourself - the satisfaction makes it all worth while.
Yes you will need to clear the code. If you don't have a "proper" code reader, you can use a $20 ELM27 adaptor off Ebay with your phone to clear it.
Old Jul 18, 2018 | 09:32 PM
jpd686's Avatar
2008 ML320 CDI
Yes I have one of those and the torque pro app as well. I’ll try that when I get a moment and hope the code stays gone!
Old Jul 21, 2018 | 08:14 AM
jpd686's Avatar
2008 ML320 CDI
Problem has been solved. Cleared code and it has not returned and turbo is spooling wonderfully. Thanks for the information guys and see ya around!
Old Feb 22, 2023 | 12:57 AM
ML320 Woes's Avatar
ML320
Turbo COntroller- Programming >???
I have a 2008 ML320 and the controller died, Been told i gotta pay $300 for "programming" on top of the part is that so ? and if it is can i program it myself ??
