Issue with Brake Wear message that will not go away. Need help with Engieering Mode.
I researched and read that sometimes the Brake Sensor Cable/Harness (part number 1645406510) goes bad, so I bought and replaced with OEM cable.
NO LUCK, the Brake Wear message popped back up as soon as I pressed the pedal.
Finally, I went into the Engineering Mode to clear the Error History and these new Warning messages showed up (attached snapshots).
Can anybody help me decrypt these codes, maybe they carry information whether it is rear or front sensors that are malfunctioning?
Thanks in advance.
