inner tire wear left front tire
Old Aug 20, 2018 | 06:06 AM
Preluden9ty3's Avatar
2009 ML 320
any suggestions as to having inner tire wear on left front tire, it is down to the wire. i assume wheel alignment is ok car drives straight and does not pull to any direction. what should i check??
Old Aug 20, 2018 | 11:18 PM
rx7turbo2's Avatar
2003 C 320 4 Matic, 2008 ML320CDI
I had a similar issue. Car drove straight, tire pressure was ok. Both front tires were wearing to the inside. I took it for an alignment and the toe was significantly out of spec on both front wheels. Don’t trust “drives straight” take it for an alignment.
Old Aug 21, 2018 | 04:42 PM
2009 ML 320
Will do just wanted to make sure there are no other common problems with suspension took a look at it and could not find anything.
