Poor FM reception on aftermarket radio
Old Aug 25, 2018 | 01:27 PM
Pastarnac's Avatar
2011 ML350 Bluetec
I decided to change the head unit with an aftermarket Android system. The unit works but I do not have antenna signal since with the small cable I have I can get a local FM station.
Q1. I have 4 coax cables coming to the OEM unit: mustard, green, blue. Which color is the FM antenna?
Q2. Which color - if any- is the reverse camera?
Per my research, the ML350 has an FM amplifier that needs to be powered.
Q3. Where do I have to apply 12V to get the FM amp powered?
See below the back of OEM unit and the main connector.
Old Nov 21, 2018 | 02:00 PM
freddienux's Avatar
2009 ml 350
Pin 7 on that white block tap into that's your power antenna wire.
