wipers
Old Oct 4, 2018 | 02:43 PM
broncoupe's Avatar
W164 ML320
wipers
Hi have a 2007 ML the front wipers don't operate
But if you turn them on and pull the wiper arms to work you can move them through a sweep
if you turn wiper stalk off they will not move which is write
I tried to read codes with some software but it can only access the engine and stability system all other systems wont communicate with it
Could this be a fault with the front SAM unit
indicators electric windows all work fine
thanks
Old Oct 5, 2018 | 01:33 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
If you can move the wiper arms by hand, then the wiper transmission is faulty. See if anything popped off.
File Type: pdf
File Type: pdf
Old Oct 5, 2018 | 06:17 AM
broncoupe's Avatar
W164 ML320
I removed the motor and it’s free put motor back on
turned wipers ON they didb1 cycle perfect then nothing
I am thinking either power issue hence why I could move them by hand when turned ON as if not enough power to push motor
could it be a SAM or relay problem ??
Old Oct 6, 2018 | 08:35 AM
Under no circumstances should you be able to manually move the wiper arms, so it is not a power issue. It is the wiper motor or the transmission arms that get attached to it.
Old Oct 6, 2018 | 09:04 AM
broncoupe's Avatar
W164 ML320
I really don't want to disagree with you because I need your help
please think of it this way if you have a slow electric window you can help it up or down with your hands if someone presses the window button
this is the same but its a wiper motor its as if its seized but its not it just needs a kick ie a pull to work through its sweep
Old Oct 7, 2018 | 11:18 AM
Yes I agree. That is why I said it could be the motor.
Old Oct 7, 2018 | 11:30 AM
dbldpr's Avatar
Veteran: Navy
I agree the motor
Old Oct 7, 2018 | 12:09 PM
broncoupe's Avatar
W164 ML320
will get another motor
do they need coding or any setting up to the front SAM
Old Oct 7, 2018 | 12:32 PM
No, it is not included in the instructions.
File Type: pdf
Old Oct 8, 2018 | 02:13 PM
broncoupe's Avatar
W164 ML320
Even odder took battery earth off just to let everything settle
reconnected the battery turned ignition On
turned wipers to 1st position they did 2 complete wipes with a small delay then nothing
Checked motor its not hot this must be electrical not mechanical
Old Oct 8, 2018 | 02:33 PM
broncoupe's Avatar
W164 ML320
Do you know where front SAM is its not by the battery under drivers seat
There is a unit there but it just has a few fuses I thought front and rear SAM units looked similar
Old Oct 9, 2018 | 02:07 AM
broncoupe's Avatar
W164 ML320
tried another motor that doesn't work at all
the SAM unit was next too the battery under a curved plastic cover that is also bone dry
Old Oct 9, 2018 | 02:43 AM
broncoupe's Avatar
W164 ML320
giving up taking it to an indie today
will post what they find to help others
Old Oct 9, 2018 | 10:19 AM
It's right next to the battery.
Old Oct 10, 2018 | 07:23 AM
broncoupe's Avatar
W164 ML320
Sorted
2 yellow relays replaced in engine bay fuse box
all good now
thanks for info hope this helps another member
