Climate control malfunctionontrol is operating normally, in the A/C
Old Dec 4, 2018 | 07:24 PM
brucerman's Avatar
2008 ML320, 2004 BMW 540/6 sp., BMW R1200Rt motorcycle, Harley-Davidson Softtail Deuce, 1998 Hewes f
Truck is an '08 ML320, 150K miles.
When I shut the engine off, the Climate Control is acting normally, in the A/C mode. (I'm in Florida) But the Auto light is not lit, in the control knob.
When I next start it, all the red lights in the center are lit up, and the fan is on high. The Auto button is not lit. To turn down the fan (and the red lights) I press the Auto button. The A/C goes back to operating normally, but the Auto button is not lit. If I press the "OFF" button, all the red lights come back on, and the fan speed goes to max.
So there're two modes:
(1) Press "Auto", A/C works normally, but the "Auto" button is not lit.
(2) Press "OFF", fan goes to Max, all the red lights are lit. This is also the mode when the vehicle is first started.
Is this a problem resulting from a failed blower motor controller?
Old Dec 5, 2018 | 10:32 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Yes it is probably the blower motor. Remove the cover under the right side of the instrument panel and check to see if there is water damage.
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 7, 2018 | 01:38 PM
Elchins's Avatar
Mercedes Benz ML350 4MATIC W164
If you do not mind, can you please send me repair manual for w164 2009 ?
Old Dec 7, 2018 | 05:10 PM
brucerman's Avatar
Maj. Dundee, thank you, for the knowledge and the quick response!
Brucerman, in Florida.
