Check Your Spare Tire Inflation!!!!
The jack, tools, and shorter bolts, along with a brand new space-saver sized spare tire were all where they were supposed to be in the space beneath the rear storage space. The spare felt firm to the touch, but once it was mounted, it was very obvious that it hadn't been re-inflated since it rolled off the factory assembly line. When I lowered the vehicle down on to the tire, it looked no more than half inflated, probably less. A quick search revealed there was a Discount Tire store only 4 miles further down the interstate. I put the flashers on and limped that 4 miles at about 40 mph, knowing that my front spare barely had enough air in it.
I agreed with the service writer that the sidewalls of the flat tire were very suspect and likely ruined after having been driven on, so I chose to purchase a new tire in order to feel safe over the last 700 miles of my trip home. Of course, they didn't have a tire that matched what is on my ML, so I now have a new one of those on order so I will once again have the same make and model of tire at all four corners. We got the new tire mounted, inflated the spare, repacked all of the stuff that had to be moved to access the spare and jack, and made the rest of the drive home uneventfully.
But this experience was a great reminder that it's always an excellent practice to regularly check the inflation of the spare tire, which should be 60 psi. When I got home, I check the spare in my wife's 2014 ML, and it was at 26 psi - it too obviously had never been inflated since leaving the factory. Needless to say, I added air to bring its inflation up to spec. I was just extremely luck I got my flat where I did. I could have been stuck in some remote location and it would have been a real disaster. So, if you haven't checked the air pressure in your spare tire recently, I urge you to do so. You really don't want to get a flat only to find out your spare is nearly flat too!!!!
