Can I replace a bi-xenon headlight with a halogen without any problems?
Old Jan 9, 2019 | 10:00 AM
kino1161's Avatar
2008 ML350 4Matic
I just wanted to know as the bi-xenons are expensive new and hard to find used. I would change both.
08 ML350
Old Jan 9, 2019 | 12:17 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
08 ML350
No, they only made bi-xenon headlamps.
Old Jan 10, 2019 | 01:55 PM
texterted's Avatar
ML420 W164 (2009)
Mine has H7 bulbs instead of xenons. They were a really expensive option over here. You'd have to re-wire away with the ballast units and maybe do some coding on Star.
Old Jan 10, 2019 | 02:04 PM
Yes, I have the same setup but I think, and I could be wrong, he is asking about the headlamps themselves. I wonder if they were damaged?
Old Jan 10, 2019 | 02:24 PM
texterted's Avatar
ML420 W164 (2009)
Yes, I read it that he want's to change the headlamps and not just the bulbs.
Old Jan 22, 2019 | 08:21 AM
kino1161's Avatar
2008 ML350 4Matic
Correct. I just wanted to know if I were to remove the bi-xenons and replace with halogen would that cause any problems?
Old Jan 22, 2019 | 01:23 PM
It's been 2 weeks since you started this thread and you have been MIA since.
Old Jan 22, 2019 | 04:27 PM
kino1161's Avatar
2008 ML350 4Matic
Your point?
Old Jan 22, 2019 | 10:51 PM
Tirgoman's Avatar
2023 AMG EQE 53
Halogens are real crap, terrible light, why would you make a backward change, except the money, think you'lll be sorry, but it's your car.
Old Jan 23, 2019 | 07:55 AM
kino1161's Avatar
2008 ML350 4Matic
Ok. I understand. Thanks, Tirgoman.
Old Oct 2, 2023 | 11:37 PM
Da Saiyan's Avatar
Mercedes Benz e350
08 ML350
Da Saiyan
Old Oct 6, 2023 | 12:57 AM
lkchris's Avatar
'10 CL550, '12 GL550
Yes you can, but you'll likely need to tell the computer system about it with your special tool.
For those without experience ...
My GL with halogen lighting ugraded to +100% H7s has better night lighting than the HID lighting in my CL. It could be because the latter is clutterdd up with night vision but anyway that's the reality.
Old Oct 13, 2023 | 07:48 PM
shawndh's Avatar
2011 ML350
You upgraded to what? You have a GL the came with halogen and upgraded the bulbs? I just didn't understand your post. I'm asking because I have H7 bulbs on my 11' and the lighting is weak. Looking for an upgrade to something brighter.
Old Nov 9, 2023 | 01:48 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
On my W203 I set Bixenon to present far in advance of
installing. The ECU in that car at least, only cares going from Halogen to
Bix as Bix uses 35 watts and Halogen 55w (stock)
So, it thinks there is a problem too little power being drawn,
turns the headlights off and then on, repeat so they end up flashing.
Point being, I knew that I would be getting Bix at some point, and
had the opportunity to have local indy to do the coding for the ECU to "Present'
with the halogen still installed and no issues. I replaced a BIOS battery in his SDS laptop
he was very greatful.
One might assume that 164 would be the same.
Old Nov 9, 2023 | 07:01 PM
Tsumi's Avatar
2006 R500
The E55 projectors (made by Hella, not the car) have a tendency of burning out the reflector surface in HID applications. They easily lose at least half of their light output due to the burned surface. Simply replacing the projectors, keeping the same bulbs, made a world of a difference on my R500.
I'm guessing he's referring to bulbs like these: https://a.co/d/jjeTyto
If you're not afraid of doing a retrofit, I would recommend swapping out the projectors for something better.
https://lightwerkz.net/collections/r...to-g5-brackets- these brackets will allow you to use one of many aftermarket projector options available. Alternatively, the Morimoto EvoX-R is a direct swap with no additional bracket needed. If you go HID, 50/55 watt ballasts will maximize light output and have the lowest likelihood of triggering headlamp warnings on cars coded for halogen. Lightwerkz usually runs 15% off sales every holiday so this coming up Black Friday might be the time to buy.
Old Nov 13, 2023 | 12:27 PM
lkchris's Avatar
Avaailability of brighter H7 bulbs is widespread. Has been for 20+ years. But, not "Silverstars" from your FLAPS. They are junk.
https://www.powerbulbs.com/us/store/...fitting/h7-499
