How to change transmission oil?
2011 Ml350 bluetech
I will be appreciated if someone can post a procedure of change transmission oil for my 2011 ML350 bluetec?
Why @$ in...why not search and read one of the many posts, online tutorials, youtube vids of such maintenance you wish to perform.
The transmission is drained and filled from the same opening ... obviously a special tool is required to do this. For something you're going to do only once, it may prove more economical to have this professionally done as opposed to purchasing the special tool. Doubt Auto Zone has this one to loan.
no special tool needed. Just a brake bleeder tool to pump fluid in and a ir temperature gauge to read temp so you know when to close it.
Heres a kit. Vin is needed to know which fluid to use.
https://www.fcpeuro.com/products/mer...ly-7229erlysk1
