Power Seat Module Removal for 2006 ML500
Old Mar 10, 2019 | 04:16 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi there,
I have to replace this module. Need to know how to remove it from under the passenger seat. The seat is stuck at the middle and it won't move back and forth. I do have access as it does move up and down.
Any guidance would be appreciated.
Old Mar 10, 2019 | 06:41 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Don't know why you think it is the control module, but I can almost guarantee you that there is a coin or similar object which is stuck between the frame and the sliding rail.
I strongly suggest you remove remove the seat and see if there is something blocking it, which is usually on the center console side.
Other things to consider are the adjustment switch or the fore & aft motor could be faulty.
File Type: pdf
File Type: pdf
Old Mar 10, 2019 | 11:33 PM
anavabi's Avatar
I just go by the code reader. I've removed and replaced all the fuses and relays in the cargo area.
Visually checked for obstructions. All to no avail.
All directions functioning but backward/forward.
Code reader specifically mentions the module is faulty. It'll be great if it's not the module.
Foxwell MB specific is the code reader.
Old Mar 11, 2019 | 03:30 PM
anavabi's Avatar
Going through your instructions, you have to be able to move the seat back and forth, something I cannot do because it is stuck. I can only remove the 2 bolts in front. The 2 bolts at the back cannot be accessed because the seat is stuck on top of them. Is there a way to just remove the cushion.
Old Mar 12, 2019 | 01:46 AM
For the bolts that you cannot remove requires Torx Box wrenches.
File Type: pdf
Old Mar 12, 2019 | 10:43 PM
anavabi's Avatar
Excellent solution thank you.
I've ordered a set; buying tools become my habit!
Old Mar 13, 2019 | 01:46 AM
The torque on the bolts are 45Nm or 33 ft. lbs.. If there is difficulty loosening the bolt use a pipe as an extension or use another box wrench that will fit over the other end and turn the wrench around and leverage it against the red points.
Old Mar 15, 2019 | 07:55 PM
anavabi's Avatar
Major,
No room to completely undo the bolt. Any further guidance please?
Old Mar 16, 2019 | 03:32 AM
Did you move the seat up?
Why won't the wrench fit?
What is the wrench size?
Post photo of why it won't fit.
Old Mar 17, 2019 | 10:46 AM
anavabi's Avatar
Did you move the seat up? Yes
Why won't the wrench fit? The wrench worked initially but space is now limited. Please see the linked video
What is the wrench size? Please see the linked video
Old Mar 17, 2019 | 10:54 AM
anavabi's Avatar
Originally Posted by anavabi
Loosened Bolt Impossible to take out
Old Mar 17, 2019 | 01:44 PM
Is the problem with the front bolts or the rear bolts?
Old Mar 17, 2019 | 02:10 PM
anavabi's Avatar
Problem is with the rear bolts.
Old Mar 17, 2019 | 03:09 PM
Remove the front bolts and lift it up about 1 inch or so & wedge something under it to hold it in that position.
Then loosen the rear bolts equally. Then lift up the rear of the seat and wedge something under it to hold it in place.
Then keep loosening the rear bolts and raise as necessary until they are completely out.
Do you understand?
Old Mar 17, 2019 | 03:42 PM
anavabi's Avatar
[QUOTE=Maj. Dundee;7707769]Remove the front bolts and lift it up about 1 inch or so & wedge something under it to hold it in that position.
Great thanks.
Old Mar 19, 2019 | 10:39 PM
anavabi's Avatar
Got the seat out! Literally millimeter by millimeter swapping wrenches and levering up and down back and front of the seat, all at the same time. What a victory!
Thanks Major.
Old Mar 20, 2019 | 02:19 AM
At least you got it done.
Old Jan 7, 2021 | 03:52 AM
CackySA's Avatar
2006 W164 ML500, 2012 W204 C200
Dead battery and seat too far back, Help
I am having the same problem, only my seat is too far back to gain access with a box spanner. Is there any way an auxiliary 12VDC supply can be given to the front seat to allow the seat to be repositioned to gain access. I have tried charging the battery both directly on the terminals and under the bonnet to no luck, DEAD as a nail... please!
Old Jan 7, 2021 | 07:11 AM
Is your battery dead?
Are both seats unable to move in any direction?
Which seat is the problem?
Old Jan 7, 2021 | 07:17 AM
Thanks Major.
And what was the problem?
Old Jan 7, 2021 | 08:10 AM
anavabi's Avatar
Thé long shaft was jammed inside the plastic gear. Plastic gear housing is pressed in so cannot be removed. Got a complete track frame. Removed the right track and replaced it. Worked out perfectly. Total cost $70. Plus hours of work, thanks to Covid 19!
Old Jan 9, 2021 | 04:18 AM
CackySA's Avatar
Neither seat could move due to no power. I managed to borrow a spare battery and used jumper cables to allow the batteries to equalise. once that happened I managed to get the drivers seat forward to access the bolts. New battery fitted and all is okay, except a new problem; i now have a SRS and other warnings on the dash from unplugging the seat???
Old Jan 9, 2021 | 04:40 AM
The SRS code is normal when the battery is low voltage or dead battery. You just have to delete the code/s.
Old Jan 9, 2021 | 07:14 AM
CackySA's Avatar
Thumbs up
Thank you Maj. Dundee, you have to be the most helpful person on this site. I really appreciate your effort. I will delete the codes and see.
Old Jan 9, 2021 | 07:31 AM
Any time.
