Headlight and brake light issues
I have a 2008 ml550. The left front low beam headlight does not work; I've changed the bulb and headlight assembly and still doesn't work. However the high beam does work so I know it's getting power. Occasionally it will work randomly as I'm driving and then go off. The same is with the left rear brake light. I've replaced the bulb and it will work for a week or so and then stop working. Any help is appreciated.
Major Dundee could probably inform you more on likely issues if you provide the vin,
But have e you looked at water intrusion in the front and rear Sam?
These are known issues.
Check for water intrusion for the front Sam. It is in the front passenger footwell. Leaks appear through the sunroof or a spilt drink.
The rear Sam leaks are caused by faulty seals of the rear taillight.
Do you have a scanner that can read codes in all of your 25 or so modules?
Did the front and rear lighting issues occur at the same time?
When the brake light problem occurs, does the auxiliary brake light come on?
Remove the left tail lamp and then remove the brake light bulb and see if there is a burn mark on the contact strip. If so you must clean & solder the burn mark to make it level again.
While you have the tail lamp out, is the seal affixed to the lamp? If so you must replace both of them as they were incorrectly installed at the assembly plant, as they should have been installed on the body opening.
The headlamp issue will be addressed after this issue.
Please answer all questions.
