ML500 wiper problem!!!
Look at this video and see if you can do it.
Do this first to see if the module cover is broken. The bolt that holds the module in place has a groove that the bolt sits in. Center the cover and with a T27 extended Torx bit, turn the bolt a bit and feel if the bolt is in the groove. Then turn the bolt a little more and feel again.
