White Battery Message
Old Jul 1, 2019 | 07:03 PM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
My W164 has a battery issue. If parked for more than 2days then it won't start. If daily driven then no problems. I decided to tackle the issue by removing the battery and have Interstate Batteries check it out. This is a AGM battery and it checked out ok. The guy said I need to check out the vehicle voltage drain.
Right after I placed the battery back, I got a white battery message. Is there a fuse on the battery that just blown? I saw a fuse on the W163 but not on W164. Which fuse should I check for alternator function?
Old Jul 2, 2019 | 04:26 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What year and model are you referring to?
Old Jul 2, 2019 | 06:21 AM
DrDoe's Avatar
This is the 07 ML63
Old Jul 2, 2019 | 02:42 PM
DrDoe's Avatar
Never mind. Ohms was OL on the negative wire that connect the main battery and the auxiliary battery. I believe it was 1/2 cut and broke off when I removed the main battery.
Old Jul 2, 2019 | 02:50 PM
You definitely have a parasitic draw somewhere in the veh. and the cause of the WHITE Auxiliary Battery message is because they are attached together by battery cables.
When you removed the main battery, the Aux. Batt. noticed that there was no feed voltage, hence the WHITE MESSAGE.
To prevent future battery drain, you must remove the NEGATIVE cable on the main battery and reattach it when you want to drive it.
