2006 ML500 LCD problem
Old Jul 5, 2019 | 02:45 PM
70TWONOVA's Avatar
2001 CL500
Hi All,
I have a 2006 ML500 (99k miles) and recently the top LCD display between the gauges started flashing in and out. Its mostly black but will flash on quickly and randomly. Is there a fix for this problem or replacement LCDs out there? The bottom LCD is working perfect. Any help is appreciated
Old Jul 6, 2019 | 04:51 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
It's a pixel problem in the cluster.
You can try and find a company that can repair the cluster but that would require laying up the truck until they return it. Or buy a used one with the same part# and hope for the best.
File Type: pdf
Old Jul 6, 2019 | 12:53 PM
70TWONOVA's Avatar
2001 CL500
I might pull it apart myself to see if I can see any burned contacts on the lcd ribbon. I worry about swapping it for another because it has the mileage in it. Or is that stored in the ECU?
Old Jul 6, 2019 | 02:56 PM
The mileage is stored in both the I.C. module and the ECM, but the pixel has nothing to do with mileage.
Here is a video of a W164, but you will have to find the pixel card first.
Old Jul 6, 2019 | 03:58 PM
70TWONOVA's Avatar
2001 CL500
Thanks that helps. I think I'll just try replacement with a used cluster
Old Jul 7, 2019 | 11:43 AM
Read step two in the PDF that I supplied.
Old Jul 13, 2019 | 11:31 AM
70TWONOVA's Avatar
2001 CL500
I bought a used cluster and the mileage on it dent show up. Just a few strait lines. I thought the mileage was stored in the ecm
Old Jul 13, 2019 | 12:43 PM
What is your vin# ?
What was the part # of the cluster and what was the link where you bought it?
Did you read step two in the PDF that I supplied.?
Old Jul 13, 2019 | 02:27 PM
70TWONOVA's Avatar
2001 CL500
Do I have to have a scan tool to do this? How do I transfer data to a star unit? My Vin is 4JGBB75E26A013735
Old Jul 14, 2019 | 10:40 AM
Yes, you must have a scan tool capable of doing it or a M/B SDS.
You didn't supply the info on cluster that you bought.
Here is the procedure to swap the data.
File Type: pdf
Old Jul 14, 2019 | 06:55 PM
70TWONOVA's Avatar
2001 CL500
I didn't realize that. I just swapped the lcd out and it's good now
