Replacing Water Pump
Old Aug 16, 2019 | 07:32 PM
Bdavis91's Avatar
'08 ML350 & '14 GL450
I'm very handy and am going to tackle a water pump replacement on our 2008 ML350. From past experience, I have learned that sometimes it makes sense to replace complementary parts when taking on a project like this one. Is it worth changing pulleys, serpentine belt, thermostat, etc. while replacing the water pump?
Thanks in advance.
Old Aug 16, 2019 | 09:24 PM
05w211wagon's Avatar
2005 e500 w211 wagon
i would check the serp belt for any cracking and replace if necessary. Then i would remove the belt and spin the pulleys ( check the water pump pulley esp for any corrosion) and idles for any noisy bearings and replace as necessary. it probably wouldn't hurt to replace t-stat and fresh coolant while you are in there. but as always "if it ain't broke don't fix it".
hth
Old Aug 17, 2019 | 05:10 PM
CLK Group's Avatar
2008 ML320CDI 4Matic, 2006 C350
As it happens I just saw this video with Alex changing the water pump on his E55 AMG. Alex is a former Mercedes Master Tech who advises to go ahead and replace all your mentioned items.
Old Aug 17, 2019 | 11:52 PM
Bdavis91's Avatar
Thanks for the reply and the suggestions.
