2011 ML350 front impact sensor.
Old Sep 7, 2019 | 05:44 PM
Ken Spring Tx's Avatar
2011 ML350 4Matic
Yes I know I shouldn't have tried to short cut but I was frustrated... HELP!!
Team, I need your help... I thought I was changing a driving light bulb on the passenger side front when the connector broke off... Well, when the connector broke my SRS light came on... Needless to say, I was pulling on what I now think is a front impact sensor... Totally trashed it ..Can anyone confirm plz... And if so, what is the part number and how can I replace it.. thanks in advance!!
Old Sep 7, 2019 | 06:52 PM
2011 ML350 4Matic
I figured it out.. as an fyi, if you loosen the two top headlight bolts, you can pull it out enough to see the bolt holding the unit on and it gives some room for your hand to fit from behind as well.. thanks again..
