ML350 Clanking noise when moving / turning
Old Sep 15, 2019 | 04:22 AM
mauzilla's Avatar
ML350
Over the last couple of days, we've been hearing quite a disturbing sound coming from my passenger side front wheel. I can reproduce the issue when the car is turned on and I turn far to the right. During this sound the car also seems to "lift" right after the sound. What is more worrisome is that when I brake, the car seems to be steering / pulling to the right hand side. I seem to loose control momentarily and upon leaving the break I regain full control. It definately sounds like something is loose specifically coming from the passenger wheel side, I cannot determine if the sound is coming from the shock area or a connected part.
I am taking the vehicle in tomorrow to have a check, but I would like to "arm" myself with as much possibilities from other MB fans
Old Sep 15, 2019 | 04:36 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Brake are worn down completely and now you have metal to metal contact, or you caliper is locking up.
