Rear SAM Symptoms
Here's what happened:
Before I removed the Front SAM, I ran the code reader once more, and this time no code was registered. I checked the SAM, there was no sign of moisture, rust, or debri of any kind. I checked under driver seat, as well as the rear SAM location, same again, no sign of moisture, rust,....
The engine shut off really scares me. I'm thinking maybe it was because I was running the code reader with the engine running. Could this be the reason for the sudden engine shut off?
I've been driving the car since with no drivability issue, but always on the lookout.
All the codes you posted before were in the I.C., correct?
Were there any codes in either SAM?
Where did you jump start the truck, at the main battery or from under the hood?
Here is a PDF on the failing steering wheel buttons.
I got problems with my 08 ML63 left taillight acting up, rear gate does not open or close, radio light is dim, rear left door lock. i suspect its my rear sam. but i actually opened it up it dont show any water damage at all.
so i guess wires are shorted somewhere. wonder how am i going to find the problem
well after playing around with all them wires putting everything in place and checking with my tester when i put everything together my taillights started to work right i get nomore errors.
only problem left is my Power liftgate doesnt go up or down on its own. softclose does work. i wonder how can i pinpoint that problem.
But i did some scanning and i will post pics here maybe that will be more helpful and specific.
Sunroof works fine
Rear left door seems to be fine, any ideas?
