V Belt Sitting off on Tensioner Pulley
Old Oct 28, 2019 | 12:51 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi,
2008 ML350,
I noticed that the V belt sits on the tensioner pulley off by about 1/8". All other pulleys look fine.I was wondering if it's normal for these engines or is there something I can do to remedy this. Please see attached photo.
Old Oct 29, 2019 | 04:54 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The belt part number depends on the vin#. Post your full vin#.
Old Oct 29, 2019 | 08:48 AM
anavabi's Avatar
4JGBB86E48A313123
Do you mean replacing tensioner and the pulley? If so, would you post the torques too. Thanks
Old Oct 29, 2019 | 09:25 AM
soldr230's Avatar
2012 C250 coupe 2007 ML 350
I went outside and looked at my belt. My 2007 (ML 350) Mercedes serpentine belt does not extend further than the pulley.
Old Oct 29, 2019 | 09:28 AM
Originally Posted by anavabi
4JGBB86E48A313123
No, I'm trying to find out what the proper belt number should be. Just hang on.
Old Oct 29, 2019 | 09:41 AM
Your 18 96 belt has been replaced with an updated one.
Old Oct 29, 2019 | 09:47 AM
soldr230's Avatar
Mr. Major, I believe that I have caused some confusion. I recently posted a pic of my serpentine belt to highlight the fact that it does not extend further than the pulley. I am not the original poster.
Old Oct 29, 2019 | 09:50 AM
soldr230's Avatar
Hi,
2008 ML350,
Does your belt have the part number on it? If so, is the part number visible?
Old Oct 29, 2019 | 09:56 AM
4JGBB86E48A313123
Here is the proper belt that should be on your pulleys.
For whatever reason, M/B does not supply instructions for removal of the belt for 272 Engines. The attachments are the best I can do.
Old Oct 29, 2019 | 10:05 AM
anavabi's Avatar
Thanks Major, I'll check the number.
I'm going to remove the tensioner just to see what it's like on the loose. I'm thinking it might have warped over time. Just to check. So I need your help for the torque when reinstalling the tensioner.
Thank you
Old Oct 29, 2019 | 10:15 AM
What does this mean and why do you want to remove it.................I'm going to remove the tensioner just to see what it's like on the loose.
Old Oct 29, 2019 | 11:09 AM
anavabi's Avatar
To see if I can spot the warp by placing it against a flat surface
Old Oct 29, 2019 | 11:25 AM
But the issue is not with the pulley, it's with the belt. The dimensions of the belt have changed.
Old Oct 29, 2019 | 11:35 AM
anavabi's Avatar
It's fine then, thanks again.
Old Oct 29, 2019 | 02:39 PM
soldr230's Avatar
Thank you
As for the torque specs, it would be in your best interest to purchase the WIS material.
Old Oct 29, 2019 | 11:27 PM
anavabi's Avatar
Old Oct 29, 2019 | 11:37 PM
pgsurface's Avatar
83 300D 617T(retired), 96 E300 606n/a(retired), 99 E300 606T(retired), 07 E320 BT, 14 E3504M
Thank you
The two fasteners for the belt tensioner on most 272 engines require 35 Nm during re-installation. Before you R&R, there is a pin hole that holds the tensioner in the install/shipping position that will make the job much easier if you stick something in it to hold it.. (see photo).
Old Oct 30, 2019 | 12:56 AM
anavabi's Avatar
Thank you pgservice
Old Dec 8, 2019 | 06:58 PM
Comalley1's Avatar
2011 E350 Wagon
What was the final answer to belt ha hing of tensioner
While changing my serpentine belt on 2011 E350 I noticed that the belt was hanging off the tensioner pulley also, what was the final answer to this, is it supposed to hang off by about 1/8"?
Old Dec 9, 2019 | 12:43 AM
anavabi's Avatar
No it's supposed to be dead flush.
please have a look at this thread from the beginning.
Old Dec 9, 2019 | 03:25 AM
Comalley1's Avatar
2011 E350 Wagon
So was the issue that the belt installed was wider than the OEM belt? The belt I took off was also hanging off the pulley.
Old Dec 9, 2019 | 10:16 AM
anavabi's Avatar
I haven't changed it yet as I don't use that car often. I reinstalled the belt and it looks ok so far. I'm keeping an eye to see if it comes back. OEM is very costly.
