PO172, PO175
Old Nov 26, 2019 | 02:29 PM
Annabanana100's Avatar
2006 350 ML
PO172, PO175
Hello, need help again please! 2006 350 ML 3.5 V6, 4 matic, 272.967
113,523 miles. Scanner is Snap On, Modis Ultra.
changed fuel pump and on deceleration skips a bit.
Any ideas? Thank you!!!
Old Nov 27, 2019 | 08:52 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
These two codes refer to too much/too little gas or too much air/too little air being delivered to both banks.
80% of the time it is an air delivery problem. Remove the air filters and hold them up to the sun. If you do not see the sun coming through the filter/s, they must be replaced.
If the filters are not the problem, check to see that there are no vacuum hoses that are cracked or broken. Then when reinstalling the air filter housing make sure that the rubber tube is fitted correctly to the Throttle Valve Actuator.
Only use the last two PDFs.
Old Nov 27, 2019 | 12:07 PM
2006 350 ML
Thank you!
You are the best!
