AutoTalent | Renntech Ecu + Suspension + Transmission For Mercedes-benz ML 320 CDI
Old Dec 4, 2019 | 12:27 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and Driver Reliability
Significant Gains in Horsepower
Increases the Performance
Significant Gains Torque
Increasing the Engine's Rev Limiter
Incredible Performance Gains
Stock Performance
230 Hp / 389 Lb-ft
Modified Performance
253 Hp / 464 Lb-ft
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
RennTech Five Speed Transmission increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. Renntech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech 722.6 Five Speed transmission upgrade consists of a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings, electrical connectors as well as a new transmission pan filter. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
Renntech V3 Digital Suspension Lowering Module
Click HERE to order V3 Digital Suspension Lowering Module!
The RennTech V3 Digital Lowering Module (DLM) is designed to work with all available Mercedes Airmatic or ABC (Hydraulic) Suspensions.The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments. The DLM requires no splicing or soldering to the factory wiring harness. The RennTech harness utilizes the factory pins as to allow a completely reversible installation. The unit also supports speed-dependant lowering that allows the vehicle to return to its factory ride-height at a pre-set speed. This removes the need for the vehicle to be aligned after lowering. The user can maintain the factory longevity and still have the lowered look at low speeds. All RennTech DLMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently.The software also has three locations where the user can store pre-configured suspension setups for quick changes.
Features
Current Consumption: 30mA (60mA while plugged in to PC/Tablet)
Adjustment increments: 1mm
Maximum Lowering: Limited only by vehicle
Adjustment Methods: PC or Android (Tablet)
Size: 53mm x 73mm x 24mm
Weight: 1.2oz
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
