Anyone know what part # this is?
Old Jan 16, 2020 | 12:50 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Hi all, got 08 Mercedes ML63AMG vin# 4JGBB77E38A353315 Transmission cooler line is leaking. Can anyone give me a part # for the bottom line that goes to the thermostat please? Thanks in advance
File Type: txt
ATT00001 (2).txt (23 Bytes, 47 views)
Old Jan 16, 2020 | 01:54 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Here you go. I do not know which one is which.
Good luck.
Old Jan 16, 2020 | 02:10 PM
IgorE350's Avatar
Good luck.
Thank you sir!!!!
i wonder how hard it is to replace it. Called the dealer they said $49plus tax for the line. looks like part is not that expensive.
Old Jan 18, 2020 | 04:40 PM
lkchris's Avatar
'10 CL550, '12 GL550
If there are washers or o-rings they need to be new ... ask dealer.
Old Jan 19, 2020 | 06:26 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
According to your vin# here are the part numbers.
There are no o-rings.
Old Jan 19, 2020 | 11:26 AM
IgorE350's Avatar
Thank you guys!!! how do they come off? i never took line like that off. do them rubber looking nuts need to be replaced?
Old Jan 19, 2020 | 03:57 PM
chassis's Avatar
2017 GLE350 4MATIC
WIS AR27.10-P-0501-03CW for a C300 with 722.9 7G-Tronic says first of all to clean the mating parts, to avoid contamination in the lubrication system. The rubber dust covers come off, then you will see a wire retaining clip that needs to come off with a "hook", as WIS calls it. I would use an awl or narrow thin blade screwdriver. The wire retaining clip needs to be replaced, it is a single use part. Replacing the wire clip requires careful work to install the clip into the fitting without bending it, prior to insertion of the cooler line into the fitting.
For the ML63 with 722.9 7G-Tronic I was not able to find this specific instruction in WIS. However, the connector looks like it is the same type.
Old Jan 20, 2020 | 07:16 AM
Here is the procedure for removing the Trans. cooling line.
File Type: pdf
