Turbo switch off
Old Jan 25, 2020 | 04:46 AM
Arn Silvester's Avatar
'06 ML320 CDI WFC1641222A118464
Question Turbo switch off
Hi people....I have an intermittent problem where the turbo in the car switches off. It sometimes turns back on again while driving after a couple of minutes and sometimes doesn't. Restarting the vehicle clears the problem 50% of the time, otherwise starting from cold in the morning normally works. Diagnostics say that the turbo is being switched off due to low fuel pressure, but can't pinpoint what's at fault. I'm guessing fuel filter (changed...didn't help); injector blockage/glowplug problem;or is it possible the fuel pump slows for some reason?? Anybody have this problem or a solution?
