I want to replace rear coil springs on a 2011 ml350 without airide
Old Jan 29, 2020 | 04:33 PM
Jxp's Avatar
Jxp
Ml350 Blu tec
Hi I have a 2011 ml350 blu tec 4 matic without air ride, the rear passenger spring is broken toward the top of the spring, and I want to replace them in pairs, the oe springs has a white stripe then my question is could I purchase the Bilsteins at a price around $65. or do I have to buy OE at $170. each??. also the rubber mounts thats on the top and bottom of the original spring should probably be replaced also, I would guess thats only available through MB?? Also has anyone used the $65-75 dollar coil spring compressors thats on E-Bay and amazon ?? they look like they will work on this ML !! Thanks In advance, PS if anyone has part numbers Please share them, Thanks Again, Joe
Old Jan 29, 2020 | 11:14 PM
chassis's Avatar
2017 GLE350 4MATIC
Please post your VIN. One of us can look in EPC for the part number specific to your vehicle.
Old Jan 30, 2020 | 01:35 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
After reading this I hope you will be discouraged.
File Type: pdf
Old Jan 30, 2020 | 07:44 PM
Jxp's Avatar
Jxp
Ml350 Blu tec
Heres the vin 4JGBB2FB2BA702367
Old Jan 30, 2020 | 09:52 PM
chassis's Avatar
2017 GLE350 4MATIC
A1643240404, coil spring, color marking: 1x white, quantity=2
I would use OEM springs. Spring rate, ride height and durability will likely be closer to original specifications.
Old Feb 3, 2020 | 08:46 PM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
I'm running bilstein rear coils on my son's C320. No difference from OEM. I'd run them on the ML also, if I had to.
Old Mar 5, 2020 | 04:29 PM
Jxp's Avatar
Jxp
Ml350 Blu tec
part number for bilstein coil springs
Hi I would like to know the correct part number for bilstein rear coil springs. Has anyone used bilsteins on a 2011 ml350 blu tec?? My oe springs have a white stripe on them, Thank You, Joe
