I am getting the Active Headlights Inoperable message. Is that a ballast replace?
Old Mar 9, 2020 | 07:30 AM
kino1161's Avatar
2008 ML350 4Matic
When starting the car and the headlights go through their up, down and side to side check, my driver-side headlight doesn't move. It remains in-place. Is that a ballast replace or do I need to purchase an entire new headlight? Any help would be greatly appreciated.
Old Mar 9, 2020 | 08:06 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
There is no guesswork when it comes to Xenon as every everything is extremely expensive.
The codes must be read in the left Xenon control module.
File Type: pdf
Old Mar 9, 2020 | 08:38 AM
kino1161's Avatar
2008 ML350 4Matic
Thanks! I'll try and pull the codes this evening.
Old Mar 9, 2020 | 08:47 AM
You will need a scanner, not just a code reader, able to read all modules.
Amazon Amazon
Old Mar 9, 2020 | 09:13 AM
kino1161's Avatar
2008 ML350 4Matic
I have a Foxwell NT520. I thought that could pull the codes.
Old Mar 9, 2020 | 01:15 PM
So that means that you were not able to read codes in Xenon?
Old Mar 9, 2020 | 01:44 PM
kino1161's Avatar
2008 ML350 4Matic
I meant to say....I think that can pull the codes. I will try this evening. On another note, do you know if I can replace with two halogen headlamps and it will not throw any codes?
Old Mar 9, 2020 | 02:59 PM
It will be a nightmare doing it as the wiring and sockets are entirely different.
