Power Steering pulley
Old Mar 10, 2020 | 10:56 PM
Portyansky's Avatar
Ml350 4matic
2011 ML350 4matic Gas
I have a sqeeling coming from the pulley of the power steering pump. Does anyone know if the pulley itself can be replaced, or does the whole pump need to be replaced? And a part # replacement would be very helpful if there is one. Thank you for your help.
Old Mar 11, 2020 | 02:32 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Unfortunately the pulley is not sold separately. But have you checked the fluid level?
Usually the O-ring on the reservoir leaks fluid and causes air to get into the system and causes squealing.
File Type: pdf
Old Mar 11, 2020 | 06:49 AM
Portyansky's Avatar
Ml350 4matic
I have not, but I will check that. Thank you!
