Fuel Pump Experts
I checked lots of threads with people replacing the pump and then it not working, but not mentioning what the fix was.
Those who have performed this, can you chime in the best practices for doing both sides at once?
And for those who had issues get the pump to work once installed, what did you do to fix it?
Thanks. Here's the VIN in case someone wants it.
4JGBB86EX6A056126 2006 ML350.
No codes.
There's no fuel pressure, the
fuse is good. Relay is good, swapped with horn relay,
Mileage just over 200K which is when my C Coupe's pump failed.
just as glad not to,
New pump, filter/sending unit, and new sensor, plus
oil change, and some repair to fix a
power steering pump leak, the reservoir or something and seals.
$1500 smackers later....back on the road.
