08 ML550
Did the radio problem occur before or after the wet SAM?
Is there anything else that is not working in the vehicle?
Do you have a scanner?
Did the load comp. fuse box get wet?
Explain the problem with the door lock. Try and be precise when stating a problem.......What happens with the door lock and which door, front or rear.
As for the fuel gauge, it is controlled by the fuel level sensor in the tank, to the rear SAM to the Inst. Cluster.
So the problem is with the rear SAM. Post your full vin#.
If the problem persists try and get a used one with only the part # as per your vin#.
Also, here is a copy of your DATA card with all your features.
