2007 ML320 CDI turbo actuator
2510 - [1] Check component Y77/1 (Boost pressure regulator). Positioner signals fault.
2510 - [2] Check component Y77/1 (Boost pressure regulator). Positioner signals fault Y.
2263 - [1] LIN message from component 'Generator' faulty Faulty message or timeout
3117 - [1] Check component Mass air flow sensor. Right Offset drift
from checking other posts it seems to be the turbo actuator. Is this a common failure on these engines? also have a leak on the driver side (USA) so left side of inside the suv. It’s near where the turbo and intercooler pipe connect as I can see some oil residue. Can the turbo be leaking? Sorry for the long post
