OM642 oil leak front of the engine
Old Jan 23, 2021 | 02:00 PM
albi.ad8's Avatar
W164 320 cdi MY 08
Hello, I hope you are fine. An oil leak was detected today where the plastic part meets the metal part in the marked part as in the attached photo. Is there an oring / seal that needs to be replaced? If so, I
would appreciate your support for the part number. Many Thanks!
Old Aug 19, 2024 | 11:36 AM
pjhiggins's Avatar
2011 GL350
I have this same issue. Did you ever find out what the fix was?
Old Sep 8, 2024 | 09:43 PM
MudFoots's Avatar
ML350 bluetec and Mini Countryman S All4
I had the same issue! It ended up being the oil filter housing. Everyone said oil cooler but the independent mercedes mechanic I found figured it out.
