4 attempts to close lift gate. Intermittent issues.
Do these shocks or whatever you call them go bad? Or what would be anything if anything I can do to fix it and not visit dealer for diagnostics?
PART 2 QUESTION
in addition to the ongoing tail gate issues ie opening and closing problem, exists a secondary problem with the liftgate handle being depressed it will fully lock into that position and get stuck. Usually calls tele aid and u have to stick a screwdriver in there to pry it back to it’s original position. — FIXES?
sThanks,
Steven
Last edited by 2008ml550_0104; Feb 24, 2021 at 06:09 AM. Reason: Not getting reply’s
You can access the pump under the spare tire, it takes a special type of Shell aviation oil.
As for the handle getting stuck, try spraying sillicon lubricant and see if it fixes things.
Finally, another bad component that went bad and won't release the tailgate when opening was the hatch lock actuator.
Good luck.
Good luck.
I’ll take a look when I get a second this afternoon.
If there are no problems, leave everything as is and crawl into the cargo area & have helper close the tailgate.
Then remove fuse #40 in the cargo fuse box & reinsert. Then have helper click (do not hold) on outer door handle. Post results.
