ABS Bleeding Instructions?
Old Feb 26, 2021 | 04:06 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Any instructions on how to bleed the ABS pump would be very helpful. I have a scanner that supposedly can do it, but I'm unware as to the correct method.
Many thanks
2010 ML550
128,000 km
Old Feb 26, 2021 | 05:57 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The ABS Pump (red arrow) is attached to the hydraulic unit. This pump is strictly an electrical component which pumps the fluid throughout the brake lines (green dots).
The only bleeding system is the same as it's always been. Pump the pedal, open the bleeder and so on. Pay attention to PDF on which bleeder is opened first in Right Hand Drive.
File Type: pdf
File Type: pdf
Old Feb 26, 2021 | 07:40 AM
prktkljokr's Avatar
12 C200, 12 C180, 10 Fuso Warrior crew cab, 08 RTV ute, 05 Smart Fortwo cabrio, 09 Smart Fortwo
Had to do this myself not long ago, ended up just doing a pressure bleed with the right machine, ( pumping fluid into the reservoir at the right pressure and bleeding each brake nipple ), I thought I could bleed it with the Autel but could not, looked for it in the Mercedes section but it was not there, I asked a Indy how they did them and they said just to pressure bleed it.
Old Mar 1, 2021 | 06:26 PM
BlackML550's Avatar
Thank you Major. it seems I've misinterpreted the need for an ABS Brake Bleed. It did seem a bit odd to me given I'd bled the brakes and assumed that procedure would have flushed the ABS pump. So, is it safe to assume that the ABS bleeding is either not required, or only if you've had to change the pump?
Old Mar 2, 2021 | 03:27 AM
If you are only replacing the red arrow pump, no bleeding is necessary. But if you are replacing the entire ESP system below the pump, then you must bleed.
Old Mar 2, 2021 | 08:16 AM
chassis's Avatar
2017 GLE350 4MATIC
Bleeding the ABS seems like a Chevy thing. Not part of the MB WIS procedures.
Old Mar 3, 2021 | 09:26 PM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
I usually just gravity bleed everything dry and refill. The End.
