Bluetooth device for music
Old Apr 18, 2021 | 06:15 PM
Ivanix's Avatar
ML320 CDI 2007
Hi all, I was wondering if there is any way I can use this Bluetooth for listening music as well. Right now only works for phone calls.
Thank you!
ML320 CDI W164
WDC1641222A291733
Old Apr 19, 2021 | 11:17 AM
k31ron's Avatar
2011 ML350
yes a few options... I use CoolStream CarPro
Old Apr 19, 2021 | 05:36 PM
Ivanix's Avatar
ML320 CDI 2007
thanks for that. How did you connect it? I don’t have any iPod connector or at least cannot see it as I have the original CD charger installed in the glove department. What I did is to install a Bluetooth device in the AUX of the Command, but not happy as it doesn’t show songs titles and cannot control through steering wheel, also sometimes calls go through that device instead the original one and obviously I cannot talk.
My question is if the MB original BT adapter cradle I showed you in the pic before can be use for music as well? If it’s not possible how should I connect another BT device to be controlled through Command? Happy to remove the CD charger and connected it there if that’s possible.
many thanks!
Old Apr 19, 2021 | 05:41 PM
k31ron's Avatar
2011 ML350
Sorry not sure then mine goes to Ipod connector in glovebox I think if your an Apple user then you might get song titles etc on the display but mine with Android doesn't. Just basic back and forward, tbh in my setup there isnt much advantage over aux. sorry not more help.
