Strong smell of fuel and leak on the under tray
I noticed a small puddle of what i originally thought was Oil on the pavement where I had parked for an hour earlier. on further inspection I used my finger to move the Oil from the tray and the liquid was clear and smells like Diesel. Its located under the rear passed side seat. I filled it to the brim 2 days ago and have only just noticed, has anyone else had this problem and know what i need to fix or is it because i may have over filled the car?
location of leak
Under tray picture
Extent of leak
Main source of leak from those two nuts
location of leak
Under tray picture
Extent of leak
2020 E 300 Coupe and 2019 GLS 400
I had the same problem. The fuel filter on that side had a hairline crack. Suggest also to replace the fuel pump at the same time to save on labour if possible.
Good luck
Good luck
