Maintenance suggestion
purchased a used 2011 ml350 with 105,000
miles
bought it from an Autohaus type dealer
they “go “ over the car for inspection
pretty sure they do what is necessary to sell the car
it is in good condition
What should I do to it for a baseline maintenance
all cars have some idiosyncrasies for that model
what have you owners experienced with your ML models second generation??
Thank you !!
when should this be replaced
read an article saying if it goes dead car will not shift into gear
leaving the wife stranded somewhere
Has anyone had this happen?
I would change the air filters. $20 on Amazon, Puralator 1 has an amazing filtration/flow curve, the best if you actually care about filtration, not just throw a dirty rag over the intake....I mean a "K&N. If you live in a sandy area, you can wrap them in pantyhose to pre-filter. While it's apart, spray carb clean the intake with the MAF disconnected / removed partly / pulled aside Then clean the cold MAF wire itself with appropriate MAF cleaner.
Run some E85, a gallon or two in a tank of gas to clean the system out, then maybe 2-cycle in the gas, 3oz/10G...double the first time....just get a gallon of Supertech or Pennzoil 2-cycle at WalMart, the best $10 you can spend.
I got the NGK Rutherium plugs, they rock and it's easy to swap. https://ngksparkplugs.com/en/product...um-spark-plugs
That's all I did to my ML, and it runs great.
https://smile.amazon.com/Valvoline-D...r_1_3?dchild=1
