General ?
Old Jul 28, 2021 | 01:24 PM
2008ml550_0104's Avatar
08' ML550, ML 63, E55, and 2019 S63, 19’ Porsche 991 911 Speedster
General ?
General question. Hello all, I was wondering if anyone has any led actual experience in having a mechanical problem with the W164 (550 m273) steering rack problems later in life…? Specifically, the steering wheel making knocking noises, when turning. 1. If it is a rack a d pinion and if so 2. Can it be rebuilt by a trained pro or myself and if this 3. Solved the problem. Just wondering and thanks.
Old Jul 29, 2021 | 07:55 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
This problem is always with the steering coupling, either the flex knuckle under the instrument panel or the knuckle in the engine compartment.
Liberally spray the knuckle with WD40 in the eng. comp. and then turn the steering numerous times back and forth.
If not, do the same to the knuckle inside.
File Type: pdf
File Type: pdf
