Drivers Door Lock Removal
VIN WDC1641282A449850
Many thanks.
It's hard to apply force without damaging the paint or something else.
I've got it all stripped down to the metal. There's one bolt on the outside of the door, under the door handle, preventing removal of the regulator/door lock assembly.
Of course you have to remove the lock cylinder before you can remove the door handle!
I think my cylinder is snapped internally. With the mechanism stuck in the "locked" position. This is preventing the cylinder from releasing from the door lock.
Like I say "I think my cylinder is snapped internally. With the mechanism stuck in the "locked" position. This is preventing the cylinder from releasing from the door lock."
As with texterted, the first procedure does not work, there is something more tightening the cylinder.
In the other hand, I'm trying to avoid removing the door lining.
My request is addresed to know what is sticking the cylinder, aside of the well known 20-torx nut
