Looking for an ML
Old Aug 19, 2021 | 09:35 PM
Tenaclubs's Avatar
ml 320
Looking for an ML
OK guys whats to problem list on these, I've bveen looking at 2010 and up ML320 4Matics
Old Aug 19, 2021 | 09:42 PM
chassis's Avatar
2017 GLE350 4MATIC
To help with your shopping, model year 2011 was the last of the W164 chassis, which is the forum you have posted in. If you are considering an ML from 2012-2015, these are on the newer W166 chassis, a very reliable platform.
Are you looking specifically for a W164 2010-2011, or are you also considering 2012 and newer W166 models?
Old Aug 19, 2021 | 09:46 PM
Tenaclubs's Avatar
ml 320
No no nessesarily that year, just a few that are still a W164 that are for sale in my area. What woulf be an advantage to a 2012 and up that I would noticew, just looking for a reliable car
Old Aug 19, 2021 | 10:03 PM
E55Greasemonkey's Avatar
This place is a joke.
The only real problem would be a diesel engine.
Old Aug 20, 2021 | 05:21 AM
Tenaclubs's Avatar
ml 320
not looking at diesels, just gas V6's , ML350's 4Matics
Old Aug 20, 2021 | 07:19 AM
chassis's Avatar
2017 GLE350 4MATIC
W164 seems to be known for leaking rear taillamp gaskets which allows water infiltration into electronics at the rear of the vehicle. This wreaks all manner of havoc. Gaskets can be replaced but checking for water damage could be hit or miss. W166 seems to be cured of that but suffers in some vehicles from a split liftgate gasket which allows water into the liftgate latch area and causes problems.
W164 rear liftgate is powered hydraulically which can causes problems at high mileage/age. W166 uses electric which seems to age better and is easier to replace when needed.
W164 uses hydraulic power steering and mechanical (cable) parking brake. W166 uses electric power steering and electric parking brake. I prefer the electric systems.
I am biased toward W166 obviously but the W164 can be good if you avoid the diesel and can make a solid determination on the rear taillamp gaskets.
Buying the newest and lowest mileage vehicle in your price range is a good idea to adhere to.
Old Aug 20, 2021 | 09:54 AM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Test drive an ML550, and compare it to the to the ML350, ......... you may be surprised and may want a 550 after that experience.
How do I know? Because this is what happened to me.
Old Aug 21, 2021 | 05:45 AM
Tenaclubs's Avatar
ml 320
I have no need for the extra power, it's a winter/snow vehicle
Old Aug 21, 2021 | 12:14 PM
S70Houston's Avatar
I see. You will l NEVER pull anything, go up a mountain range, try to pass anyone or anything, ...
Got it.
Old Aug 21, 2021 | 12:27 PM
Tsumi's Avatar
2006 R500
One pro of the 550 engine is that it won't have the balance shaft issues the 350 engine has.
Old Aug 21, 2021 | 12:29 PM
S70Houston's Avatar
In all fairness, not ALL 350 engines are affected by the balance shaft issue, but one of course needs to do their homework.
Old Aug 21, 2021 | 08:25 PM
Tenaclubs's Avatar
ml 320
Got it.
Hey I have a Ford F250 Diesel pickup, tuned , large injectors, 6-peed manual trans and over 600 Lb/Ft of torque when I " pull anything, go up a mountain range, try to pass anyone " that will outpull you any day of the week with a 35 foot 5-th wheel (oh ya wait thats right you can't pull one of those can you) up any mountain you wanna try. So before you go shooting your mouth off this isn't for pulling anything and there aren't too many mountains in Northern Wisconsin and it's for the wife anyway so hey, nice try but Check Mate bud
Old Aug 21, 2021 | 08:30 PM
Tenaclubs's Avatar
ml 320
Just love how some idiots THINK they know what someone on the other side of the country whom they never met in their lives , knows just what I need. Geez, like I never bought a car before in my life!
Old Aug 21, 2021 | 09:03 PM
S70Houston's Avatar
Keep on truckin'
Old Aug 21, 2021 | 09:39 PM
You're correct, but it will have the timing chain sprocket issue.
Old Aug 21, 2021 | 10:26 PM
Tsumi's Avatar
2006 R500
True, I had thought the balance shaft issue affected all M272 engines. My mistake there.
In any case, all it means is avoid 2006-2008 Mercedes unless the engine and transmission have been replaced/repaired.
Old Aug 22, 2021 | 08:24 AM
Tenaclubs's Avatar
ml 320
Good info, thank you. I bought a fairly clean 2011
Purchased an extended 3 year 36,000 mile warranty
Old Aug 22, 2021 | 08:29 AM
Tenaclubs's Avatar
ml 320
Keep on truckin'
Hope you have a block heater for your car in Sacramento for when it gets down to 40 below zero and two feet of snow on the ground just like it does here in January
Old Aug 22, 2021 | 11:33 PM
S70Houston's Avatar
Hope you have a block hearter for your car in Sacramento for when it gets down to 40 below zero and two feet of snow on the ground just like it does here in January
What's a " block hearter"?
Old Aug 23, 2021 | 05:33 AM
Tenaclubs's Avatar
ml 320
I misspelled and corrected but you still wouldn't know anyway. Again thank you for your time.
Old Aug 23, 2021 | 09:15 AM
S70Houston's Avatar
Here is the thing, ............ you have 12 lousy posts on this forum and act like a real macho man, ...... big truck, huge trailer, blah, blah, blah, ......
No one called you any names on here, yet you cannot spell or are capable of proof reading your posts, but you call others "idiots"???
Think again, ......
And further more, maybe some of us "idiots" are not willing to live where you do, as we do not want to freeze our butts off, nor do we want block heaters on our cars!
Good luck with your 2011 ML350, I will no longer respond to your rudeness and nonsense.
Old Aug 23, 2021 | 09:05 PM
Tenaclubs's Avatar
ml 320
You mean like this,,,
Test drive an ML550, and compare it to the to the ML350, ......... you may be surprised and may want a 550 after that experience. How do I know? Because this is what happened to me.
I see. You will l NEVER pull anything, go up a mountain range, try to pass anyone or anything, ...Got it.
Ya big truck, I got lots a power blah blah blah blah
Promise, I don't want your advice I already had enough of it. I misspelled one word and you of coarse never did in your life
And after I told you what it's used for, here is your bragging smart remark
Got it.
Not knowing even what the vehicle is to be used for, and it's for my wife. Which I already stated a winter/snow vehicle Like she would need extra power. For what to haul grocery bags? Shows after I even told you how little you pay attention, All about you isn't it?
Your the one that shot his mouth off and all I did is respond the way you did. You reap what you sow, and I came on here looking for any problems with an ML350, you right away try to tell me I don't know what to buy because it won't pull anything up a mountain (that doesn't even exist here). Because people like you know so much about me. Now guess again, YOU DON'T. And on top of that I answered your statement and then you come back with that smart remark and when I call you on it then you get mad because it didn't work and I didn't listen. Now when someone gives you what you gave them your all mad? It's the pot calling the kettle black bud. And again don't worry I don't want your advice.
Old Aug 23, 2021 | 09:06 PM
Tenaclubs's Avatar
ml 320
To those that helped thank you, I bought the car and it checks out pretty nice. Hopefully a lot of good miles left, Thanks again
Old Sep 6, 2021 | 03:43 PM
makiii's Avatar
E400 Wagon; 2010 ML350; 08 CLK350 Cabriolet; 69 SL280
Congrats on the purchase,
We have a 2010 ML350, got it in 2012, it is primarily my wife's car and the "trip" car as I drove a 08 CLK350 Cab & then and Audi A5 Cab. It might turn 80,000 miles this week. Below is the 1 of the only issues we have had with car in 9 years.
"W164 seems to be known for leaking rear taillamp gaskets which allows water infiltration into electronics at the rear of the vehicle. This wreaks all manner of havoc. Gaskets can be replaced but checking for water damage could be hit or miss. W166 seems to be cured of that but suffers in some vehicles from a split liftgate gasket which allows water into the liftgate latch area and causes problems."
Other issue
Passenger side mirror motor went
this past July we finally had the original spark plugs replace, any other work on the car has been maintenance based on the MB schedule.
at the rate this car gets driven its like the a service is done this year and the B next. My wife and have long discussion on getting her a new car but when it get down to it - she likes the interior of the 2010 best and then the 2021's . Doesn't like the amount of vinyl from bottom of dash to the center console - think it looks cheap and I agree.
the 2010 ML has/is a great car, roomy, hauls stuff and is comfortable.
