Radio Stays on after Car OFF
I have a 2007 ML350 that recently had the water thru the tail light and sunroof flooding to the Rear Sam issue...Now after repairing this the Radio is still having this issue...if i would leave the radio on after turning off the Car...the radio would turn on by itself after a couple minutes way after i leave and lock the Car...causing dead battery all the time...Does anyone know how to tackle this ????
Not keyless ...i have noticed if i pull the driver door hard enough while locked i can force open the door..
2002 ML 320 & 2006 ML500
Do you mean pulling the door handle? If that is the case, the open the door the spray the latch (red arrow) with WD40. Then using a flat tip screwdriver, push the latch all the way forward and then pull the door handle. Do this procedure until the door locks properly.
ok Awsome ..thank you....yea the door can be locked and closed..but if i pull on the handle a lil hard it will open....would this help for the radio too ?
