2008 ML350 Belt Noise
Old Aug 26, 2021 | 04:53 PM
anavabi's Avatar
2006 ML500, 2008 ML350
I have this noise when the engine is cold. When I pour water on the belt, the noise goes away. Also when the engine gets warm, the noise goes away. Your insight please.
lease watch the 10 second video at the link below.
Old Aug 27, 2021 | 08:08 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Did you inspect the belt?
To me, that noise is a bad pulley, namely #3 & #6.
File Type: pdf
Old Aug 27, 2021 | 10:52 AM
anavabi's Avatar
Thanks Major.
Do you think there is an explanation for the water and the warmed up engine causing the noise going away?
Old Aug 28, 2021 | 01:06 PM
When the eng. is cold, remove the belt and spin pulley #3 as fast as you can with your two fingers. If the pulley makes noise or spins very fast, then it must be replaced. Then do the same for #6.
Old Aug 28, 2021 | 02:26 PM
anavabi's Avatar
