2008 ML350 Rear SAM replaced and programed no power seats
Old Oct 31, 2021 | 08:25 PM
wolffman514's Avatar
2008 ML350 4matic
Rear SAM was bad from water damage. I replaced and took it to have new SAM Coded. Now Front power seats wont work. put old SAM back in and they work. so its something with the new SAM. Any thoughts?
Old Oct 31, 2021 | 09:03 PM
E55Greasemonkey's Avatar
This place is a joke.
It's been programmed incorrectly. There's a coding in there that's a little tricky to understand about the seats. Whatever it was set to, the opposite needs to be selected.
Old Oct 31, 2021 | 09:06 PM
2008 ML350 4matic
ok.. thank you for the information. I will have to take it back in to the repair place and have them look at it.
Old Nov 1, 2021 | 11:33 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You must extract the data in the old SAM and then transpose it into the new SAM. See highlighted area in PDF.
File Type: pdf
Old Feb 4, 2023 | 03:33 PM
carl0sgarcia's Avatar
w164 w163
I have the same issue except before the sam change fuel and seats didnt work. i bought a used one and now the fuel works but not the seats. xentry states it does not see the seats. this makes me believe its a connector or wire issue. the old one was corroded and cleaned. i'm open for suggestions.
