Overheating problem, please help
I did take the fan off and replaced the 2 bearings and visually inspected, all look good i dont see anything abnormal, cleaned magnets. Didnt install it back yet. Any Ideas if its not the fan? could it be a relay? temperature sensor? or anything else i can look for? thanks for help in advance.
I replaced bearings and installed fan back in to the car, it still does the same thing and makes the same noise. from the code and the noise that it makes i think its the fan motor is bad.
ordered another fan today, should be here in few days.
Does the fan got relay?
If the fan is working but not a full revolutions, then it is not an elec. problem.
You need a new fan.
Is that normal for ml63 for temperature to go 105C for the fan to start working?
Thank you again for your help GOD Bless!
Was driving today, temperature stayed around 90C to 99C wile driving on the freeway outside temperature around 55F
Then let the eng. cool down. Start the eng. and select A/C and see when the fan kicks in.
Been driving the car for few days no problems no messages on the dash
