Backup Camera
Old Nov 23, 2021 | 11:20 AM
'93 300ce's Avatar
'95-E320 COUPE, 2000 SL500, 2002 ML320
Backup Camera
I am getting a blurry and darker picture when my backup camera is activated, its impossible to use at night. I've cleaned the external lens without improving picture quality. Any ideas on how to improve the image quality?
This 2009 ML320 has the factory installed backup camera.
Thanks for you help.
Old Nov 23, 2021 | 03:12 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Need a scanner to read codes in the Backup Module.
File Type: pdf
Old Dec 8, 2021 | 05:32 PM
'93 300ce's Avatar
I've had the backup module scanned no codes are indicated. The service tech is advising to replace the camera because the blurriness is on the inside lens. Is there a way to open the camera and clean the inside lens? Is there an after market camera that is plug n play with old one or is the OEM one my only choice?
Old Dec 9, 2021 | 12:16 AM
I do not know the answers to those questions.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 28, 2021 | 07:18 AM
Newbarn29's Avatar
2008 ML550
I just bought my ML, and it had a very similar problem. I had to replace my head unit because the previous owner had spilled coffee on (and somehow in) it. The replacement head unit fixed the problem with the backup camera.
Old Dec 29, 2021 | 11:21 AM
'93 300ce's Avatar
Thanks for your reply. Without any error codes my next step is to start replacing components, camera and then head unit.
