Auxiliary Battery malfunction
I have the message "Auxiliary Battery Malfunction" displayed.
Does this mean the auxiliary batter is bad? There is no "visit workshop" displayed. Also, it went away after being displayed once.
If it is going bad, is this battery located behind the main battery so everything has to come out again?
Thanks.
Thanks.
Benzdom (12-03-2021)
I don't have a charger for such a battery - so this means I cannot install it myself?
Thanks!
What's the best place to buy an auxiliary battery? Amazon has almost 2 weeks delivery time.
2002 ML 320 & 2006 ML500
The Aux. Battery has only one use and that is if your main battery is faulty you will be able to put it into NEUTRAL so your veh. can be towed.
Actually, I drove for an hour today and the warning didn't come on. So it's likely on the brink.
My main battery is only six months old. Shop should have exchanged the auxiliary as well.
I don't have a voltmeter, either. So it looks like I shouldn't be doing this thing myself.
Invest in this tool. Plug it into the front 12v socket and it will tell you what is the battery voltage while the eng. is off and eng. running.
https://www.amazon.com/Charger-Adapt...8780218&sr=8-1
If I plug it in I will see the main battery's voltage, not the auxiliary battery's, yes?
The aux battery is essentially an Uninterruptable Power Supply (UPS) battery, AGP type (fiberglass-matt in the electrolyte).
If you've a second vehicle and have a nearby store like Batteries+ (really any battery specialist store) - you can pull the battery and take it in for a match.
(Assuming you haven't already ordered one online)
I replaced mine with a Duracell UPS battery with the same capacity and physical size, it works fine. Cost me about $25-30.
There's absolutely no reason to by Mercedes-branded battery for this.
