ML350 Bluetec Wheel size 18"?
Old Jan 29, 2022 | 10:13 AM
metelhead's Avatar
ML350
Just joined the forum! I'm picking up 2010 ML350 Bluetec next week (its in service for emissions right now). I actually had 2008 ML320 cdi long ago so pretty excited to jump back into the MB.
Currently this ML has two sets of wheels; stock 19" and a set 20" wheels....However I'm looking to get a bit more sidewall for light 'soft roading' and would love to put some 18" on it with a ratio of 60 or 65 on them...likely 30"-31" tire (19" tire choices are a bit limited too).
-So anyone know if 18" will clear the calipers?
I found this chart showing wheel sizes ranging from 17" to 21"...but no ideal if thats actually true with clearance of brake calipers. Additionally searched quite a bit without finding anything substantial on the topic (likely most go the other direction).
Thank you Josh
Old Jan 29, 2022 | 06:53 PM
mRaposo's Avatar
ML350 2009 CDI
Good Night
A1644011502 is the part number of an original wheel 18" size for ML 350.
So I believe that is no problem using it.
Old Jan 30, 2022 | 02:10 AM
Tsumi's Avatar
2006 R500
Check your brake rotor diameter. If you have 350mm front rotors or smaller, 18" will fit.
