VRP M113 N/A Conversion Kits Now Available!
The VRP M113 NA conversion kit includes all of the pulleys you need to swap your NA to a K.
This kit includes the VRP supercharger Pulley and idler set, boost bypass delete, a new belt and thermostat housing!
You will need:
- Factory M113k supercharger with intercooler and surge tanks
- A custom built intake and PCV
**It is recommended that you run at least 550cc injectors with this setup**
**as of right now VRP does NOT sell or provide technical support for the fuel, tune, or ECU for this setup**
The current method of supercharging an NA is to swap to a virginized K ECU and wiring harness.
**you will be required to cut the Secondary air pump bracket off the timing cover.**
Only $800!
Available here
