Slow starting - cranks for a while before it finally starts
AMG GTS (2016), GL63 (2016), SL63 (2022) -- Old Cars: E400, CLS 63s, ML 63, CL 600, S550 ...
All of our MB vehicles start more or less instantly when they crank. My daughters 2008 ML did as well - until recently. The car cranks (nice and fast) but does not start for anywhere from 2-5 seconds or more. No "almost" catching during that time. It just cranks as though there is no fuel, and then decides to start perfectly - but after too many seconds of cranking. As I say, this is new behaviour.
The car is not throwing any codes - the scan comes up clean on my iCarsoft MB 3.0.
Any suggestions on what to look for?
I searched around and didn't find this posted anywhere - apologies if I missed it.
Thank you all so much!
The problem solved until the starter failed ( didn’t seem like a starter problem) but starting 1st try every time after replacing new starter.
I would start with Replacing Crankshaft and Camshaft sensors. One that is still working but on its way out will exhibit non running conditions and may not throw a code until its gone kaput. Their cheap insurance and alot easier to do in your garage with a cold engine rather than stuck in the middle of nowhere with a hot one.
My m113 did something similar, sometimes would start immediately, other times would take a good 5 seconds before catching. Camshaft sensor seems to have done the trick. Also no codes when it was acting up.
Many thanks for the tip.
