Airmatic - several parts already replaced
Currently my car is sitting with the front right fully compressed with the front left not far off completely sagged. The compressor runs and tries to pump it up but it doesn't seem to raise at all. The rears are sitting happy at the correct height.
Some history:
- front left bag was replaced 3 months ago
- front right bag was leaking and replaced 2 days ago
- compressor was replaced yesterday. Car height was raised and lowered with no issues
- car worked for a day before the airmatic malfunction light came on. The front right drooped slightly (1 inch lower than the front left) when I arrived home. Then after jacking the car up and then back down, the front is right is flat while the front left now sits very low (1 inch higher than the front right). The compressor constantly runs but no height is gained (switches off after it gets hot)
- soap spray used and no leaks found on the lines or bags or compressor
- soap sprayed on the valve block but no signs of leaks (difficult to see the whole block)
- I tried scanning for codes by my OBD tool didn't pick up any codes (not a STAR tool)
Do you have any suggestions or ideas for further diagnostics?
Thanks in advance
Some history:
Thanks in advance
Thanks for the help!
