Battery compartment pre fuse box removal
Old Feb 8, 2023 | 07:09 PM
06ML350#34's Avatar
ML 350 (W164)
Does anyone know how to remove this? I don't wanna break anything.
Old Feb 8, 2023 | 09:07 PM
06ML350#34's Avatar
ML 350 (W164)
I figured it out. Push that black tab in with your fingers and pull it towards you, it should release (circled in red). To remove the fuses with the wires you simply pull up on them with a little bit of force (yellow arrows). The three red wires that connect to the left of the device you can unscrew with a socket. Larger red power wire that connects to the middle of the device also gets unscrewed with a socket.
Old Feb 9, 2023 | 06:54 AM
Dewey Dog's Avatar
2009 ML350 4matic
Good to know. Why are you removing?
Old Feb 11, 2023 | 11:19 PM
06ML350#34's Avatar
ML 350 (W164)
I've been going through the electrical system looking for corrosion. I've been having parasitic drain issues. I cleaned the can under the passenger seat and it cured my "running light" inside the headlight issue. I've found the data link connector can have this issue as well. I've pulled the driver seat and have the carpet pulled back. Gonna finish removal and inspect it, clean it and hope it works lol
Old Feb 12, 2023 | 07:15 AM
Dewey Dog's Avatar
2009 ML350 4matic
Wish you the best of luck with that. I had what I deemed a parasitic draw as well. Car had sluggish starting for about 6 months. Went thru all of the fuses with a multimeter and nothing of note. New gel battery and aux battery as well 1 year before and posting 12.6V consistently. Come to find out that I had two problems: 1. I had changed out the puddle lights in the bottom of front doors so that when they opened, they iluminated a MB logo. The passenger side went out and I never knew it until wifey mentioned it to me. For whatever reason, the light actually works but the connection is very intermittent so that may have been drawing energy. I put the OEM light back in and it works fine. Not certain how much drain this might have caused but it's a thought. 2. My difficulty starting ends up having been the starter. Two weeks ago it finally bit the bullet and had to be replaced. New starter and the car starts like a champ and no longer exhibits any symptoms of a parasitic draw. So there you have it. Could have been both issues combining or just the starter. Guess I won't know for certain unless in the next 6 months I notice difficulty starting in which case I'll go hunting for a draw somewhere else.
Old Jan 26, 2025 | 02:22 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Would you please how to pull that 30A fuse out without removing the battery. Thanks
